5083 5086 Aluminum
4
5083 5086 Aluminum
5083 5086 Aluminum
Hello
I have been in the aerospce business for @ 15 years. At times I come across blueprints that call for 5083 or 5086 aluminum. While investigating these I found that the stuff is hard to come by. Also the prints that call this out seem to all be from the 1980's. Has a different aluminum taken it's place and if so is there a mil spec to referance. Any help would be greatly appreciated.
Chuck
RE: 5083 5086 Aluminum
5086 is indeed tough to find.  From what I've seen, I believe that 6061 is used in situations where 5086 used to be, but I may be wrong.
raptor2,
   According to my Atlas Alloys handbook, Aluminium 5083 is the highest strength aluminium there is in the annealed condition.  It is also very resistant to corrosion.  The last time I specified this material, I was told it was "shipping plate".  Obviously, it is the best aluminium grade for welding ships together.  You might investigate a marine supplier.
   6061 probabaly is not a good substitute for 5083 because it is much harder to bend, it is weaker in the as-welded state, and it is not as corrostion resistant.  5052 is popular with sheet metal shops.  Perhaps you should consider that.
   Is this stuff being used for the airframe, or for something mounted inside the aircraft?  I thought they used 2024 for airframe.
                                JHG
try cem sales 800/737-0023 they have shapes, pipe & profiles for marine applications
serious inquires please and they have a website
http://www.metalsalesusa.com
