Solidworks Journal File Location
Anyone can help me set SW so that it saves the journal file swxJRNL.swj in the same folder as the open file?
In Tools / Options / File Locations / SW Journal File you can only set s specified folder, I guess.
Note: I am using SW2004 under Win2000.
Thank you much,
Sorin
Thank you much,
Sorin
RE: Solidworks Journal File Location
Why do you want to do that?
One way is to always change the options settings with the actual location of the file.
Another way (I don't know if this works in SW2004) is leaving the options settings blank and start SW doble cliking the file in W2K explorer.
Those are not very partical procedures but, again, why do you want to create the journal file in the file folder?
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
The reason I thought this may work better for me was to always separate the commands for a specific working session, and of the specific part I work on . Does it make sense?
Sorin
Crashj
If you have SW Closed, then use Windows Explorer to find the file and double click the file. From there the journal file will be created. If you open up another file the journal file is still located in the first place where the file exists at.
Scott Baugh, CSWP
FAQ731-376
As discussed before in other threds, the journal file as no pratical utility, unless you want to check some particular API instructions of SW, to help you writing some macros.
I suggest that you select one folder to save journal files, so you can control it's creation. Otherwise you will sun have your disk with journal files everywhere.
