Barrier adhesion to asphalt and concrete
We need to glue a base of a barrier device for parking spaces, for applications where anchors are not allowed. The barrier yields after 200 lb. is applied horizontally at a height of 15" from the ground. If curious, the application can be seen on www.dp-corp.com.
Any suggestions as to the best adhesives, and what surface area will we need to provide?
RE: Barrier adhesion to asphalt and concrete
