FLOATATION VESTS
FLOATATION VESTS
IF AN IRON WORKER TIES REBAR INSIDE OF A REBAR CAGE FOR THE CONSTRUCTION OF A CONCRETE BRIDGE PIER IN THE WATER SHOULD HE WEAR A FLOATATION VEST. REMEMBER THE IRON WORKER HAS A UTILITY BELT WITH ABOUT 25 LBS OF HAND TOOLS, WEARS INSULATED COVERALL AND GLOVES. ALSO THE REBAR CAGE PROJECTS ABOUT 15' ABOVE THE WATER LINE AND THE REBAR CAGE IS BEING BUILD INSIDE OF AN 8' DIA CAISSON. THE IRON WORKER MUST BE LOWERED INSIDE OF THE CAGE WHICH HAS ONLY ROOM FOR HIMSELF. I SURE WOULD LIKE TO GET SOME FEEDBACK FOR THIS TYPE OF SITUATION. PLEASE BE AWARE THAT SUCH CAGE HAVE BEEN KONWN TO BUCKLE. I KNOW ABOUT THE OSHA REQUIREMENT FOR WORKING OVER WATER W/ A FLOATATION VEST AND BODY HARNESS BOTH OF WHICH MAY NOT BE A SATISFACTORY SOLUTION AGAINST DROWNING.
RE: FLOATATION VESTS
aspearin1
