Centering sketches
Centering sketches
It' easy to center a circular sketch on a circular solid using a concentric relation, but how do you handle rectangles or squares? Is there an easy way to center a square or rectangular sketch on the square or rectangular face of a solid?
Tom
Tom
RE: Centering sketches
Or make a Midpoint relationship to the middle of one of lines using some construction geometry.
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
This way I use no dimensions to center the sketch.
I can't tell you how many times I have opened parts created by other workers and there are dimensions all over the place, where sketch relations could be used to clean everything up.
-Dustin
The diagonals of a rectangle are equal length. The diagonals intersect at their mutual centerpoint.
Or, control select both the origin and the diagonal and make a midpoint relation.
The last method seems to have the benefit of requiring 7 clicks, one less than the others.
1) Select a plane
2) Start a sketch
3) Stab my "hot key" (I use S)
ITS GOLD!!!!!
Tom
