copy a drawing
copy a drawing
hi
i just start with pro/e
can some one telle me if it'is possible to copy a drawing from this enviromment to other under windows ( word, autocad,....) and is there any labrary for electrical drawing ( one lines diagramme, logics,...)
RE: copy a drawing
To copy the drawing, select FILE, SAVE A COPY, change the Type to TIFF , change the drawing name if required and change the directory, if required. You can then insert this into WORD, EXCEL. For AUTOCAD, I think you will need to change type to DXF. I'm not sure as we don't use AUTOCAD.
As for the library, I've no idea as I am MEchanical.
Hope this helps.
maybe only a drafter
but the best user at this company!
RE: copy a drawing
There are so many ways it is incredible.
Everything grom a screen dump to exporting a DXF.
I generally export them as PDF files so any one can READ them. I must point out that once you do this the drawing will become a "DUMB" drawing an you will loose all the parametric associativity that makes this program great!
The termanology you are looking for is called a symbol in Pro/E. I am sure there are elecrical templates for the system somplace, I would do a google search for {"Pro/E" "symbol library" electrical). That shoud yeild something of use. You create a drawing (or part) and place the line symbol on your print.
Hope that helps. I can see that the by the verry nature of your question that you have a lot to learn. I hope that time is fun and enjoyable!
JOSE FIGUEROA JR.
RE: copy a drawing
im4cad
Pro Design Services, Inc.
http://www.cadproe.com/pds/home.asp
