How to insert BMP into Acad200 dwg?
I have inserted them using Insert-Raster Image.
However, empty rectangles are displayed if the source files change location (meaning only references were inserted, not bitmaps themselves).
It's Acad2000 under WinXP.
RE: How to insert BMP into Acad200 dwg?
I'm not sure what You mean, but You can't insert images into Autocad. An image is like a reference. You have always two files!!!
If You change the names of the folders or paths AC wouldn't find the images.
Exception: *.bmp and *.dwg are in the same folder. Then You can move both into another folders...
Lothar
Flores
