S.S. #12 TEK Screws, Pullout Values in 6063-T6 AL
I am looking for a resource for information on Allowable "Pull Out" , Tension loads for S.S. #12 Tek Screws in 6063-T6 , Aluminum. The Aluminum tube section is 0.15 inches in thickness. I have tryed " The Aluminum Association", they have no data on this subject.
RE: S.S. #12 TEK Screws, Pullout Values in 6063-T6 AL
I found an example in "The Aluminum Association - Aluminum Design Manual" Example 30, PgVII-67. Any farther input is welcomed. Thank you, in advance
