Prompt for Parameters at Startup?
I'm a new user of SolidWorks, but am quite familiar with modling software as I have been using Pro/E for years. I have to say that I am very impressed with SolidWorks on the surface. But anyway, in Pro/E it is possible to prompt the user to input parameters for part number, description, material, etc. at creation. Does this functionality exist in SolidWorks? I would like to make it so I can prompt the user for the part number, description, and designer name at startup (possibly by using a template). Any help on this matter would be greatly appreciated. I searched through the forum, but wasn't able to find anything on this. If it has been discussed, please point me in the right direction.
Jason
Jason
RE: Prompt for Parameters at Startup?
Hey, sounds like a new API project!
Under the CUSTOM tab are some predifined parameters. You can also create your own. These custom properties can be used to populate fields in things like boms,revision tables, title blocks, etc. So what I have done is set up a templates that has these custom properties predifined. Example PARTNO is the property and the property text field says "ENTER PART NUMBER" Everytime you open a new part the properties I have defined are there. So this is does not automatically pop up when a new part file is opened but what does happen is when you make a drawing of your part or assembly the custom properties automatically populate the title block. Once a person sees "ENTER PART NUMBER" or "ENTER PART MATERIAL" or "ENTER VENDOR NAME" all over the title block they know they need to go back to the part or assembly file and enter this information.
