Default setting catia v5r12
Hello ,
We just installed catia v5 r12, and i create a new drawing from catia template title block.
But all the lines have the color white. Do you know where i can change this default color?
RE: Default setting catia v5r12
This sounds like a known bug. Try removing you CATSettings. This should fix the color problem. The default color command no londer exists as on V5R10.
Stefan
