Rotated viewport
Rotated viewport
Rotated viewport
Is there an easy way to insert a view in paper space that is rotated 90 degrees?
RE: Rotated viewport
Try this, it will not mess up your orientation in model space.  It will only rotate the view in the viewports
Double click in the viewport
DVIEW
Selec a couple of the objects
TWist
90
Enter
Enter
Let me know if that is what your were looking for.
DemarEngr
Yes that is the command I was looking for.
Thank You,
Hello CRG...
For rotate a viewport you write in command line the MVSETUP command. Next select the option Aling, next Rotate view. Next AutoCAD ask Specify basepoint in the viewport with the view to be rotated: you select a point in center of viewport. Next AutoCAD ask Specify angle from basepoint: you specify the angle... This is all :D
Un saludo de SpeedCAD... :)
CHILE
