'97 UBC Fig. 18-I-1 Setback Dimensions
As an engineer on the development end of things, my clients would like an answer to this question.
The term "H" in the aforementioned figure represents the overall height of the slope. "H/3" represents the required distance to daylight.
The question is how to define the term "H". If it is to be defined as the entire height of the slope - from the bottom of the creek bed to the top of the ridge - then the solution for "H/3" obviously becomes un-workable. However, if it is to be defined as the height between two points at which the slope levels off, then two questions arise: 1.) how level do these areas have to be, and 2.) how far should these "level" areas extend in order to be considered effective in determining the overall height?
Can you help me define this term? All comments appreciated.
-Richard L. Flower, P. E.
RE: '97 UBC Fig. 18-I-1 Setback Dimensions
Best of luck.
