Dimension error
Dimension error
“The Microsoft Jet database engine cannot find the input table or quary ‘ISO_shaft_Fits’. Make sure it exists and that its name is spelled correctly.”
I keep receiving this popup error whenever I enter dimension any part. I also get one for ‘ISO_hole_FITS’
I can click OK on both popups and dimension as normal, but this is getting very annoying.
Any Ideas on what is wrong?
RE: Dimension error
Please provide your OS, SW ver, PC specs, etc.
RE: Dimension error
RE: Dimension error
Try FAQ559-507 to see if that fixes it.
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
RE: Dimension error
RE: Dimension error
You might try and do a repair on SW first. You can do that by going to the Add remove programs and click on change. There you can pick "Repair".
Scott Baugh, CSWP
FAQ731-376
RE: Dimension error
