Need extremly durable, light weight plastic material.
I posted this question in the materials section and then decided to post it here also. I am designing a plastic part that is 4ftx3.5ftx1in. I can design in a majority of the lightness, but need to know several materials to begin looking at. Part will see some major abuse. Any suggestions on a material to try?
RE: Need extremly durable, light weight plastic material.
You might consider PFA (PerFluoroalcoxy Resin), it's expensive but has a very nice balance of engineering properties such as rigidity and abrasion resistance, and is well suited to abusive situations - (that sounds kinda funny), but true.
Some other materials that come to mind include Phenolic, UHMWPE, HDPE, etc.
Hope that is helpful
I almost forgot, you can also probably do a search of various materials on www.globalspec.com - and on GE Plastics web site (I believe it's www.geplastics.com but not certain)
best of luck!
As per RIVetron above UHMWPE is excellent for both mechanical and chemical abrasiveness. UHMW might be a better alternative to PTFE (teflon) in terms of cost but I believe it has a higher density.
