title block information
I need some claification. We are going to go to ISO as our drafting standard and are in the process of creating new title blocks.
I need to know if we can deviate from the ISO book on the layout of the information that we put in. Some people here are saying that we can do whatever we want as long as we do it the same every time. Others say it needs to follow the layout specified by the book.
Any imput would be greatly appreciated.
RE: title block information
You need to provide some clarification. What ISO specification are you referring to?
Best regards,
Matthew Ian Loew
"Luck is the residue of design."
Branch Rickey
A search of the International Organization for Standardization (ISO) (www.iso.ch) website for "drafting standard" yielded this result:
ISO/IEC Guide 7:1994 Guidelines for drafting of standards suitable for use for conformity assessment
www.iso.ch/iso/en/CatalogueDetailPage.CatalogueDetail?C...
Is this the standard you are referring to?
Best regards,
Matthew Ian Loew
Branch Rickey
there is difficulty in understanding your question.
ISO does not publish "books". The most common type of "deliverable" is the ISO Standard. ISO also publish Guides, Technical Specifications and Technical Reports. Each deliverable has a unique number (e.g. ISO 9001) therefore if you can quote the number, this will help to define the problem.
Secondly, do you seek help with standards for drawing and draughting (i.e. making "blueprints", to use an old term that may nevertheless convey the meaning better); or with the rules for drafting the content of an ISO deliverable (such as ISO Guide 7 referenced by MLoew)?
Kind regards,
i am in a situation similar to yogibear...we are trying to get ISO certified and i am suppose to standardize all the drawings to ISO standards.but i don't know which standards to use .i need help with standards for drawing and draughting.does anyone know something about this??.
thanks
ddkb
There remains here a fundamental lack of understanding regarding ISO standards. Please clarify what you are looking for after reading through other threads in this forum.
Best regards,
Matthew Ian Loew
"I don't grow up. In me is the small child of my early days" -- M.C. Escher
for example there is a standard on title blocks,then there is a standard on the paper sizes.and so on and so forth.right ...am i even close to understanding this thing??
http://www.iso.ch/iso/en/prods-services/prods-services/otherpubs/Quality.PublicationList?CLASSIFICATION=HANDBOOKS
A publisher has compiled a two volume set of ISO documents, all of which reference "ISO" drawing practices.
The other link posted above is Guideline 7, liberally translated as "How to write an ISO standard"
Alex
thanx alexit
Nice link. Here is the table of contents that lists out the individual standards:
Technical drawings, Ed. 4, Vol. 1 Page 1 of 3
Contents
Part 1 : Technical drawings in general
ISO 128-20:1996 Technical drawings — General principles of presentation — Part 20: Basic
conventions for lines
ISO 128-21:1997 Technical drawings — General principles of presentation — Part 21:
Preparation of lines by CAD systems
ISO 128-22:1999 Technical drawings — General principles of presentation — Part 22: Basic
conventions and applications for leader lines and reference lines
ISO 128-23:1999 Technical drawings — General principles of presentation — Part 23: Lines on
construction drawings
ISO 128-24:1999 Technical drawings — General principles of presentation — Part 24: Lines on
mechanical engineering drawings
ISO 128-25:1999 Technical drawings — General principles of presentation — Part 25: Lines on
shipbuilding drawings
ISO 128-30:2001 Technical drawings — General principles of presentation — Part 30: Basic
conventions for views
ISO 128-34:2001 Technical drawings — General principles of presentation — Part 34: Views on
ISO 128-40:2001 Technical drawings — General principles of presentation — Part 40: Basic
conventions for cuts and sections
ISO 128-44:2001 Technical drawings — General principles of presentation — Part 44: Sections
on mechanical engineering drawings
ISO 128-50:2001 Technical drawings — General principles of presentation — Part 50: Basic
conventions for representing areas on cuts and sections
ISO 129:1985 Technical drawings — Dimensioning — General principles, definitions, methods
of execution and special indications
ISO 406:1987 Technical drawings — Tolerancing of linear and angular dimensions
ISO 2553:1992 Welded, brazed and soldered joints — Symbolic representation on drawings
ISO 3098-0:1997 Technical product documentation — Lettering — Part 0: General requirements
Technical drawings, Ed. 4, Vol. 1 Page 2 of 3
ISO 3098-2:2000 Technical product documentation — Lettering — Part 2: Latin alphabet,
numerals and marks
ISO 3098-3:2000 Technical product documentation — Lettering — Part 3: Greek alphabet
ISO 3098-4:2000 Technical product documentation — Lettering — Part 4: Diacritical and
particular marks for the Latin alphabet
ISO 3098-5:1997 Technical product documentation — Lettering — Part 5: CAD lettering of the
Latin alphabet, numerals and marks
ISO 3098-6:2000 Technical product documentation — Lettering — Part 6: Cyrillic alphabet
ISO 3272-1:1983 Microfilming of technical drawings and other drawing office documents —
Part 1: Operating procedures
ISO 3272-2:1994 Microfilming of technical drawings and other drawing office documents —
Part 2: Quality criteria and control of 35 mm silver gelatin microfilms
ISO 3272-3:2001 Microfilming of technical drawings and other drawing office documents —
Part 3: Aperture card for 35 mm microfilm
ISO 3272-4:1994 Microfilming of technical drawings and other drawing office documents —
Part 4: Microfilming of drawings of special and exceptional
elongated sizes
ISO 3272-5:1999 Microfilming of technical drawings and other drawing office documents —
Part 5: Test procedures for diazo duplicating of microfilm images in
aperture cards
ISO 3272-6:2000 Microfilming of technical drawings and other drawing office documents —
Part 6: Quality criteria and control of systems for enlargements from
35 mm microfilm
ISO 5261:1995 Technical drawings — Simplified representation of bars and profile sections
ISO 5455:1979 Technical drawings — Scales
ISO 5456-1:1996 Technical drawings — Projection methods — Part 1: Synopsis
ISO 5456-2:1996 Technical drawings — Projection methods — Part 2: Orthographic
representations
ISO 5456-3:1996 Technical drawings — Projection methods — Part 3: Axonometric
representations
ISO 5456-4:1996 Technical drawings — Projection methods — Part 4: Central projection
ISO 5457:1999 Technical product documentation — Sizes and layout of drawing sheets
ISO 6412-1:1989 Technical drawings — Simplified representation of pipelines — Part 1:
General rules and orthogonal representation
ISO 6412-2:1989 Technical drawings — Simplified representation of pipelines — Part 2:
Isometric projection
ISO 6412-3:1993 Technical drawings — Simplified representation of pipelines — Part 3: Terminal
features of ventilation and drainage systems
ISO 6413:1988 Technical drawings — Representation of splines and serrations
ISO 6428:1982 Technical drawings — Requirements for microcopying
ISO 6433:1981 Technical drawings — Item references
ISO 7200:1984 Technical drawings — Title blocks
ISO 7573:1983 Technical drawings — Item lists
ISO 12753-1:1999 Compasses — Part 1: Nomenclature, illustrations and equivalent terms
ISO 12753-2:1999 Compasses — Part 2: Requirements, designation and marking
ISO 10209-1:1992 Technical product documentation — Vocabulary — Part 1: Terms relating to
technical drawings: general and types of drawings
ISO 10209-2:1993 Technical product documentation — Vocabulary — Part 2: Terms relating to
projection methods
ISO 10209-4:1999 Technical product documentation — Vocabulary — Part 4: Terms relating to
construction documentation
ISO/TR 10623:1991 Technical product documentation — Requirements for computer-aided design
and draughting — Vocabulary
ISO 11442-1:1993 Technical product documentation — Handling of computer-based technical
information — Part 1: Security requirements
ISO 11442-2:1993 Technical product documentation — Handling of computer-based technical
information — Part 2: Original documentation
ISO 11442-3:1993 Technical product documentation — Handling of computer-based technical
information — Part 3: Phases in the product design process
ISO 11442-4:1993 Technical product documentation — Handling of computer-based technical
information — Part 4: Document management and retrieval systems
ISO 11442-5:1999 Technical product documentation — Handling of computer-based technical
information — Part 5: Documentation in the conceptual design stage of the
development phase
ISO 13567-1:1998 Technical product documentation — Organization and naming of layers for CAD
— Part 1: Overview and principles
ISO 13567-2:1998 Technical product documentation — Organization and naming of layers for CAD
— Part 2: Concepts, format and codes used in construction documentation
ISO/TR 13567-3:1999 Technical product documentation — Organization and naming of layers for CAD
— Part 3: Application of ISO 13567-1 and ISO 13567-2
ISO 14985:1999 Hard-copy output of engineering drawings — Specification for the structure of
control files
Best regards,
Matthew Ian Loew
