Adding draft to surfaces - error - V5
Hello.
I am using V5R10. (This is a different problem than my previous draft problem post.)
I am trying to rebuild the history of a V4 model in V5 using paste special. One of the drafts failed so I deleted it. I am trying to add draft back in the same area of the history tree. I would like to remove material for die pull. I am still getting an error and don't know how to get around it.
The error says, "Part2: Draft operator: The draft operator cannot decide whether to add or remove matter from the initial part. Decrease the anle value or change the pulling direction." Even though I need the part to look exactly the same in V5 as it did in V4, I have tried reducing the draft angle. That did not work. I can't change the pulling direction because it is die draw. What else can I do?
Thank you.
Sheryl Fredricks
Thank you.
Sheryl Fredricks
RE: Adding draft to surfaces - error - V5
Try moving the neutral plane to the larger end of the die.
My neutral plane for this draft is actually at the bottom of the set of surfaces that I am trying to draft. I want the walls to draft inward from the bottom surface. I am able to draft the walls out, but not in. Any other ideas are welcome.
Thanks again.
Sheryl
