Knowledge Based Engineering
Is knowledge based engineering working in mechanical system designs?
Modern product development is complicated. With streams of data pouring in that inform how...
Download NowINTELLIGENT WORK FORUMS
RE: Knowledge Based Engineering
I know that Knowledge-Based Engineering rules can be captured into designs in Pro/ENGINEER by PTC (www.ptc.com) through the use of the Behavioral Modeling Extension (BMX) module. This is a very sophisticated modeling and analysis tool.
PTC has partnerships with many software vendors claiming to provide "knowledge-based" solutions (www.ptc.com/search/default/r.jsp?l=mkt_partners_softwar...).
Other MCAD packages may offer the ability to apply simple rules calculations.
What is it you are trying to solve?
Best regards,
Matthew Ian Loew
"Luck is the residue of design."
Branch Rickey
Used incorrectly, it can add unnecessary complexity. The key (as with so many things in life) is to PLAN AHEAD.
