Shell Manway Cover Thickness API 650
Is there a formula for calculating the thickness of a shell manway cover plate based on the tank height. The table in API 650 is handy but I would like to use a formula in my spreadsheet to calculate the thickness given the tank height, corrosion allowance and so on. Thanks in advance, Kent.
Thanks for your help, Kent.
RE: Shell Manway Cover Thickness API 650
fo rvery large tanks the flat plate cover rotation
We developed some curves for a client for a specialty tank insert box but got strain gauging done as we were so uncomfotrtable with the thin shell behaviour.
Try fepipe for a set of results
alk
alk
The formulae are the same as UG-34 from ASME VIII Div. 1
