Using Fit or spline on polyline with broken linetype
When drawing a polyline with a broken linetype, AutoCad always starts and ends each segment on a section of line rather than a gap and adjusts the length of the end dashes if necessary.
When I edit polyline and try to fit curve or spline, the linetype is corrupted even more, often creating quite long sections of unbroken line with just a few breaks.
Is there any way to prevent AutoCad from altering the character of the linetype in this way?
RE: Using Fit or spline on polyline with broken linetype
PEDIT [pick the line] "L" and "OFF"
