TRAFO VECTOR GROUP
TRAFO VECTOR GROUP
ON WHAT BASIS WE WILL SELECT THE TRANSFORMER VECTOR GROUP?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: TRAFO VECTOR GROUP
If that is not an issue then you should buy what is standard from the manufacturer. If you buy from a US manufacturer you will most likely get a unit with the high side leading the low side by 30 degrees (ANSI standard) while IEC manufacturers more commonly have the Delta side lead the Wye side by 30 degrees (Dy1 or Yd11).
To add to brupp’s post, the topic has been extensively discussed here, as evident with a subject search.
