Freezing cheese
Freezing cheese
Freezing cheese
Greetings- an interesting but very real one- especially if you are the cheese producer & your product is delivered by a large logistics company!!  Frozen cheese- is not a good thing- dries out!
300g of cheese similar to cheddar (could be approximated as water??) at 2C.  Put into a large fridge at air temp -23C.  How long until cheese block (even surface) becomes -3C?
OK then if the cheese is covered by thin layer of wax, ok which is the covered in a thermoplastic covering?
We are looking for engineering indications 1 hour 6 hours 12 hours??  etc.
Q = h . A . (T1 - T2)
Q  heat transfer rate
h heat transfer coeff.
A surafce area
T T air
T cheese surface/ wax?
Any indications or experience appreciated.
thx.
RE: Freezing cheese
If its for real life and you are dealing with 300 g blocks of cheese - why dont you just do a test?
Best regards
Morten
RE: Freezing cheese
Hi, am doing a couple of tests with some blocks but am also intrigued at the engineering approach to take- shouldnt be diffcult, if somehow you get an approx thermal coefficient and capacity?  This is my gut feel, so putting out the bait.  Thanks for input.
RE: Freezing cheese
If I recall, the ASHRAE fundamentals handbook has data on meat,dairy and other food products such specific heats, enthalpy and heat transfer coeffecients, etc.  I no longer have a copy.
