balancing of v engine..
hi everybody
what is major aspect of balancing of inline engines and
v-engines?which engine is suitable for multistage gas
compression? (from above two engines).
any information @ multistage comprn is wellcome.
thanks
connery
thanks
connery
RE: balancing of v engine..
r u referring to rotating/oscillating masses or to balancing each individual cylinder load (large bore engine)?
as far as suitability for multi-stage compression, power is power. among other considerations, look at power/weight ratio and investigate plot space limitations (if any) for inline and v-type engines.
-pmover
V6 engines are a different story. I've had less to do with them but they typically require a balance shaft to reduce vibration. I believe that if it is a 90degree V, then there is no need for a balance shaft but you get uneven firing intervals.
Hope this helps
