how do i stop water hammer
we have a problem with water hammer on a condensate system on a chemical plant. Joints an valves are starting to leak, is there a way to stem this problem
how do i stop water hammerhow do i stop water hammer(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: how do i stop water hammer
A basic check would include reviewing closure / opening times of valves and understanding what causes velocity changes within the system. There could be column separation due to poor piping design which can aggravate the waterhammer phenomenon.
maybe try http://www.parker.com/accumulator/cat/english/1630007.p...
http://www.parker.com/accumulator/cat/english/makingcho...?
If this is the case, you need to find a way to either cool the condensate or increase the system operating pressure slightly, if possible.
For pressurized systems, sometimes the problem is leaking steam traps allowing steam into the condensate system. Or it may be a poorly operating heat exchanger (fouled or excessive flows) which is not condensing all the steam and maintaining a liquid level. Again this would let hot steam into the condensate system causing hammering.
http://www.kirsner.org/kce/media/pdfs/KirsnerHammer.pdf
Believe it or not : Eratosthenes, a 3rd century BC true philologist, calculated circumference of earth with the help of a stick and it's shadow. The error was just 4% to the present day calcuated value.
