EXCEL CELL REFERENCES
I have a multi-page Excel worksheet in which I have references to cells on other sheets, e.g.  ='SHEET2'A1.  Is there a way to have the "SHEET2" page reference point to a cell instead with the cell contents having the page I wish the reference to point to.  In other words, the formula ='SHEET2'A1 would change to '<expression for a cell reference where the cell contains "SHEET2">'A1.  The end result would be the sheet referred to in the formula cell reference would be dependent on a value contained in a cell that I include in the expression, which could be SHEET2, SHEET3,etc.  I have tried different approaches, but get only errors.
Any ideas or suggestions?  Thanks.
RE: EXCEL CELL REFERENCES
try using the INDIRECT function.(see Excel Help)
Consider the following:
      Col A       Col B       COl C
Row1  Sheet        Cell       Value
Row2  Sheet2       A1         =INDIRECT("'"&A2&"'!"&B2)
So we are building the reference with text concatenation functions, then looking up the value with INDIRECT.
I love the indirect function.  Once you get a feel for how it works its surprising how many uses it can have, and it can be an elegant simplification for what might otherwise take several operations.
