Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I'm a freelance consultant, and your site's helped me with many issues. I just wanted you to know that someone does appreciate the intelligent help your site offers."
Geography
murphy12 (Mechanical)
18 Nov 03 12:53
I have a nonstandard keyway due to space constraints and I'm woried about compression.  Is there any reason I can't stray away from standard keystock (1018 or 1045) and use something harder like 4140 Q&T?
MintJulep (Mechanical)
18 Nov 03 12:55
You run the risk of damaging the shaft in the event of an overload.  Keys are intended to be sacrificial.
18 Nov 03 13:25
Thanks. I though that was the reason, but I was wondering if there were any other reasons.
ornerynorsk (Industrial)
18 Nov 03 14:02
There is no reason that you can't use a harder material, I've used hardened keys in the past with much success.  Just keep in mind what mintjulep said, but you almost always have some repair considerations when a key shears, regardless of material.
18 Nov 03 20:42
murph,
These types of things work pretty well if you have the space.
http://www.fennerindustrial.com/products/trantorque_ind...
savis (Mechanical)
19 Nov 03 8:23
This is an interesting question.  However, you should be careful to consider what the industrial mechanic will replace this key with if they have a failure of some type.  We recently had some issues with keys fretting and found out that our stock room was stocking 6x6 keystock material incorrectly (using 6x6 square stock c-1018.  The tolerances are greater +0/-0.078, whereas keystock is +0-0.030.
Savis
Close Box
Join Eng-Tips® Today!
Join Us             Close
