Rotating Raster Reference Files
Does anyone know of a way to rotate a raster reference file to a degree other than 90, 180, or 270 in Microstation J?  I used to do this with IRASC but no longer have that software.
After it's rotated I'll need to clip it and be able to print it.
Thanks.
RE: Rotating Raster Reference Files
Yes, it's possible.
When you go to File --> Reference and then click on Display --> Raster you can select te rasterimages which you want to rotate. After selecting this just click on Tools --> Rotate and there you can choose youre wanted angles.
regardless
Hmo
