Document props
Document props
Document props
I'm having trouble finding how to copy Document Properties from a part file to another part file. I have a part template that I want to copy props to all other part files we have. I thought this could be done, but can't find it. Anyone know? thanks
RE: Document props
If you have subscription service you can down load a program that does this for free, found under the model library, API, General Utilities.  If you do not I can send it to you.
BBJT CSWP
RE: Document props
Thanks. I downloaded it, but don't know how it works. I have SW 2003 SP5.0.
RE: Document props
There is a product called "Propagator" that does batch proptery population.
http://www.customsolids.com
If the ladies don't find you handsome, they should at least find you handy.
RE: Document props
Which one did you download?  The one I am referring to is the Copy Props.  When you unzip it you double clik on the CustomProps.exe.
BBJT CSWP
RE: Document props
I downloaded it, opened it, then got a window to type some properties...but do not understand how do I get it to copy properties from one file to another.
RE: Document props
I have a homebrew addin to copy properties from one file to another, but it doesn't do batch copy.  Contact me at the email in my profile if you are interested.
RE: Document props
ctopher
I can do it by using DSOfile form Microsoft, if you are using W2K. Not shure that DSOfile works in WXP. You can shearch for related threads here, macro examples in SW site an technical explanations about how DSOfile works in the Microsoft site.
But if you are using custom props, DSOfile will not work. You have to have a macro that will batch open the SW files and copy the props to other files.
Take a loock at the PropaGator Software that can do this job (I can't give you details because I never worked with tis software).
Regarsd
RE: Document props
macPT,
DSOFile works with XP. I haven't had an issue with my routines that use it....
Mr. Pickles
RE: Document props
Thanks MrPickles.
It's time to change the PC's in my departement and now all new PC's come with XP. I was affraid to loose the DSOfile feature.
Do we need to install it as it was for W2K?
RE: Document props
I installed it just like I did on XP. I think there are (2) "versions" of DSOFile floating around out there. I have and used the one that had an "install" with it...
Mr. Pickles
