Switch off menu animation in Wildfire
I'm running Proe Wildfire on a dell precision w2k.
When using the feature dialog (e.g. protrusion), wildfire animates the "slide-up panels" (references, options,.....). This animation gets slower with every new windows, so is there a possibility to switch it off (or accelerate)? Who needs this animation anyway?
best regards,
uli
RE: Switch off menu animation in Wildfire
Not a 100% sure on this, but my guess is that this is related to the animation menus you have in your Windows operating system.  Do the drop down menus in MS Word or Excel do the same type of animation?  If so, try turning off these feature for all of windows and re-start Pro/E.
Dear Scott,
the windows-"effects"-settings have no influence on the problem. Thanks
