text in model space hidden by a view port is plotting.
AutoCad 2000 Problem
text, in model space, but hidden by a view port is plotting. The drawing plot previews fine. It is only text, that is part of an external ref drawing, that plots outside the viewport area. The xref dwg was created with R14 but was recovered and saved with R2000...this action did not solve the problem. As usual the beers are on me if someone can get me outta this stinking mess.....need more whiteout soon. Thanks people
Bumble
ps does anyone else have problems logging on this site..this is my forth time joining.....i'm just logging in as a bogus user recently. I've had my original password emailed to me so many times 'cos i thought i was going mad...but i still can't login through the homepage...I'm sure Mr. Tek-Tips doesn't know...or is he just trying to keep me out!!!!!hmmmmm Still its a great site!!!!!!
Bumble
RE: text in model space hidden by a view port is plotting.
you most likely will find this so
the work around is change that style to use one of the shx files instead of ttf files
its a glitch with acad and true type fonts
if everyone helps everybody the world will be a better place
Thanks a bunch for your help...you have got us out of the shish once more...you have a very informed head on your shoulders....Thanks again!!!!
Bumble
