liquid phase vacuum pump
Hi all
My requirement is to eject liquid water from a vessel at 0.1 bar. Now this is not hard...with many pumps being sold that will accomplish this.
The problem is it is very much a lab scale operation and i only have to remove about 1-2 litres an hour. I would ideally like to have a pump that i can have come on every 5 minutes or so. Any ideas as to firms i can contact that have pumps that will do this, in the capacity range i have.
Or do you have some ingenious way to do this. A water column type principle seems a good idea except the part that i need 9 m to generate the 0.9 bar underpressure. Mercury would of course be a whole lots easier but then i still have to purify the water so this is not an option.
I can't change the conditions to avoid the formation of water...
Any advice would be much appreciated
RE: liquid phase vacuum pump
Dear quan1tum1,
I can direct to metering pump suppliers for lab-scale process,
In the US check with LMI,(www.lmipumps.com),tel:508 263 9800
                                          Fax: 508 264 9172
In Europe check with ,Lewa (www.lewapumps.com)
Of course you have to protect your vacuum,with a liquid seal
(water)..and maintain a static head..
Good luck,
Whylie
Thanks Whylie
I have had a look at their web sites and thats exactly what I was after.
Kind regards
quan1tum1 (Ryan)
