Is it possible? (BoundaryConditions)
How are you? ^^
How do i don't know that set the boundary condition which the movement of SPIRAL.
for example, i think that the rotation(Z-axis) is possible such as 6,6, .... but don't know how to set the movement of rotating with moving in direction of center(axis) like as spiral movement.
please... would you let me know?
thank you very much...
RE: Is it possible? (BoundaryConditions)
The direction of the axis will be 3, ie. the Z axis. If you're not sure build a small model and test your boundary conditions on that.
corus
http://www.corusresearch.com
