CONVERT KA to AMPS HELP
I have a Breaker that is rated at 10KA...First I need to know what a KA is and second I am looking to convert this to amps...
Any help would be appreciated....
RE: CONVERT KA to AMPS HELP
And what do you mean by rated? Is it rated to trip at 10,000 A (10 kA)? or is this the fault current it will operate without coming apart (the trip setting being actually much smaller).... read the label vary carefully...
easy way to answer your question
if the breaker is the size of a cigarette pack then it's 10k fault current
if it's the size of a small car then it's 10k trip current
mike
How can I determine the Trip Current Amperage.
The Breaker is a Moeller FAZ-3-C32 10KA
go here and down about 1/3 http://www.kentindustries.com/catalog/Sec_9.pdf
Good link imok2.
Is this what you want?
http://www.moellerusa.net/catalog_203/10_supp_protector...
etc. for more info
