ER410NiMo impact properties
Has anybody tested this type of material with CVNs at or near 0F (-18C). We are needing 50 ft-lb and our standard FCAW and SMAW electrodes don't usually make it even at room temperature. 40-45 ft-lb would be typical. I was looking at GMAW since the CVNs are usually better than FCAW or SMAW depending on the situation. Probably spray type transfer with 98%Ar, 2% O2.
RE: ER410NiMo impact properties
It would be worth dropping Metrode a line to see if they have any better data for GMAW.
They are on www.Metrode.com
Sorry I can't help any further
