Best SS for ferric chloride
Does anyone know the most resistant stainless steel grade temperatures to ferric chloride ate ambient temeperatures?
Best SS for ferric chlorideBest SS for ferric chloride(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Best SS for ferric chloride
If there is a fair amount of air exposure or other oxidizer, then C-22 will probably work better. I've seen C-22 come out of a 3 day 6% FeCl3 test with mirror finish intact.
If 1% is an occasional maximum, perhaps one of the 6% Mo stainless steels will work (Al6XN, for example). But even 1% FeCl3 has a low enough pH that it will probably challenge this subfamily. I'd really want to see some test exposures before committing to this choice.
Dave
The temperature increases 2C for each 1% chromium and 6.6C for each 1% molybdenum. 0.1% nitrogen gives you 3.2C. Subtract for sulfur and surface abrasion..more complicated. Welding takes 10 to 15C off the rsistance. In effect you can build your own alloy.
Go for a good 10C over the intended use temperature. That says at least 2205, better 2507 or a 6%moly austenitic.
