Helical Gear with Worm
I'm currently designing a 90 degree worm gearbox. Center distance (2.066") and (approximate 10:1) ratio is known. I'd like to use a P/M helical gear with the worm instead of a hobbed bronze or brass worm gear. I cannot find much information with this combination. How do I spec out a helical gear to mate with a worm?
The worm will be rolled onto an input shaft. I'll likely use 7/8" C1045. What diametral pitch's can be rolled to this shaft?
On a sidenote, when should a hunting tooth -not- be used?
Any help would be appreciated.
RE: Helical Gear with Worm
A notable exception was a molded nylon worm running against a molded acetal gear. It worked remarkably well.
Don't know much about rolling.
There is no major disadvantage in using a hunting tooth that I know of, although people argue about the advantages. If you have a cyclic load that always occurs at the same angular location, then a hunting tooth is highly beneficial, but in general the merits of a hunting tooth are somewhat controversial. In the early days of gearing, when teeth were less accurate than they are today, it was probably more important. I believe the wooden cogs used in windmills always had hunting teeth, and the practice may have stemmed from there. Of course, if you need a ratio which happens to be factorable, you can't use a hunting tooth, which requires that the numbers of teeth be relatively prime. And if you happened to have a mechanism which relied on some sort of device which compensated for pitch error, you might not want a hunting tooth because it would vastly complicate the compensation algorithm.
Helical gears are commonly driven by clylindrical worms such as the type you are considering.
Since you are planning on using a PM gear, you may be limited on what you can do in terms of the Helix Angle of the Gear. Very few PM houses are willing to tool a helical gear especially if the helix angles are much greater than 10 degrees. This is mainly due to the type of tooling and equipment limitations. If you do go ahead, I would highly recommend using a PM house who specializes in gears, not a PM house who also does gears!
There are other options in your design that you may want to consider. For example; instead of using a helical gear, you could have a worm drive a spur gear at some other angle than a 90 degree shaft angle. You may want to consider this to keep the cost of the PM gear down.
In terms of English Muffin's comments on using an involute worm, I disagree with the notion that the worm tooth must be involute shape. Straight sided worms (in the normal plane) are used sucessfully every day in countless applications. This is primarily due to the fact that the contact pattern in this type of system is point contact, instead of over a surface. The possible extra cost involved with producing an involute worm instead of a straight sided worm is not worth it.
You must also be made aware that efficiency in such systems of of significance. Efficiencies in the 30% to 70% range are not uncommon, so in your case, the output torque would be 10 x input torque x efficiency.
Should you need more help, follow this link as this company are experts in this particular field.
http://members.rogers.com/webgear/home.htm
