Naming a worksheet
Naming a worksheet
Naming a worksheet
I have a project containing hidden worksheets, depending on the users action I need to copy and modify a hidden worksheet. Both the original and modified sheet need to remain hidden.
I have used the code
 'Sheets("BlankData").Copy Before:=Sheets(1)'
to copy the worksheet but i now wish to rename it
As the new sheet is hidden i cant use 'Activesheet' to refer to the new sheet. I have tried using Sheets(1) but again this only seems to refer to visible sheets.
Any ideas??
RE: Naming a worksheet
You can refer to the new sheet as Sheets("BlankData (2)"), as in Sheets("BlankData (2)").Name = "NewName"
Cheers,
Joerd
