need help to find brg defect freq
G'day,
Can anyone please provide me with all the bearing defect frequencies for NTN UK216 bearing? I can't seem to find it anywhere..
RE: need help to find brg defect freq
Hope this helps, from International Source Index, the bearing expert program. www.sourceindex.com
FTFI - 620.25
FTFO - 879.75
BSF - 4206.00
BPFO - 6202.65
BPFI - 8797.35
thanks to electricpete and flacrkr for your replies.
Anyway, flacrkr, the freqs that u mentioned above are based on what rotational speed? What are the multiplies of these freqs (at 1RPM)? I'm particularly looking for freqs at 286RPM.
Thanks a million
Insert Mounted Units, Taper bore 200 Series+Adapto
Bore   75.000 O.D.  150.000 Width   82.000 (mm)
       2.9528        5.9055         3.2283 (in)
Part No. UK216+H2316            Manuf:NTN                       --------------------------------------------------------------------------------
Harm              No.     B/R    Pitch
onic         RPM  B/R    Diam     Diam       FTFI       FTFO        BSF       BPFO       BPFI
   1     286.000   10  0.7490   4.3300    118.261    167.739    801.944   1182.639   1677.361
   2     572.000   10  0.7490   4.3300    236.522    335.478   1603.888   2365.277   3354.723
   3     858.000   10  0.7490   4.3300    354.783    503.217   2405.832   3547.916   5032.084
   4    1144.000   10  0.7490   4.3300    473.044    670.956   3207.776   4730.554   6709.446
   5    1430.000   10  0.7490   4.3300    591.305    838.695   4009.720   5913.193   8386.807
   6    1716.000   10  0.7490   4.3300    709.566   1006.434   4811.664   7095.832  10064.168
   7    2002.000   10  0.7490   4.3300    827.827   1174.173   5613.608   8278.470  11741.530
   8    2288.000   10  0.7490   4.3300    946.088   1341.912   6415.552   9461.109  13418.891
   9    2574.000   10  0.7490   4.3300   1064.349   1509.651   7217.496  10643.747  15096.253
  10    2860.000   10  0.7490   4.3300   1182.610   1677.390   8019.440  11826.386  16773.614
  11    3146.000   10  0.7490   4.3300   1300.871   1845.129   8821.384  13009.025  18450.975
  12    3432.000   10  0.7490   4.3300   1419.132   2012.868   9623.328  14191.663  20128.337
  13    3718.000   10  0.7490   4.3300   1537.393   2180.607  10425.272  15374.302  21805.698
  14    4004.000   10  0.7490   4.3300   1655.654   2348.346  11227.216  16556.940  23483.060
  15    4290.000   10  0.7490   4.3300   1773.915   2516.085  12029.160  17739.579  25160.421
  16    4576.000   10  0.7490   4.3300   1892.176   2683.824  12831.104  18922.218  26837.782
  17    4862.000   10  0.7490   4.3300   2010.437   2851.563  13633.048  20104.856  28515.144
  18    5148.000   10  0.7490   4.3300   2128.698   3019.302  14434.992  21287.495  30192.505
  19    5434.000   10  0.7490   4.3300   2246.959   3187.041  15236.936  22470.133  31869.867
  20    5720.000   10  0.7490   4.3300   2365.220   3354.780  16038.880  23652.772  33547.228
  21    6006.000   10  0.7490   4.3300   2483.481   3522.519  16840.824  24835.411  35224.589
  22    6292.000   10  0.7490   4.3300   2601.742   3690.258  17642.768  26018.049  36901.951
  23    6578.000   10  0.7490   4.3300   2720.003   3857.997  18444.712  27200.688  38579.312
  24    6864.000   10  0.7490   4.3300   2838.264   4025.736  19246.656  28383.326  40256.674
  25    7150.000   10  0.7490   4.3300   2956.525   4193.475  20048.600  29565.965  41934.035
    286.0000 RPM, SCALE: x1 RPM
