Concrete Slab Inside Tank Has Bulged Up
We have a 60' dia tank. From the base working up is a concrete base slab, welded steel tank bottom, 3' of granular fill and a 6" slab on a 30 degree incline toward the centre of the tank.
At approx. 17' out radially from the centre of the tank, the concrete slab has bulged up about 2'. It looks like a berm, gently sloping up and then back down. We cored holes and found the concrete slab has lifted leaving a void between the granular material and underside of slab.
Generally, the head of chemical in the tank is 12' above the elevation of the slab at the area in question.
Core samples showed a supersaturated granular material so we know the chemical is getting under the slab and being trapped by the steel tank liner below.
What could make the concrete heave up like this?
RE: Concrete Slab Inside Tank Has Bulged Up
Has the density of the current chemical increased with regard to the design density? Has the head increased from the design head?
Does the tank foundation have a ring beam?
If this is the case, I suspect that the shell has buckled circumferentially.
VOD
Settlement of the ring beam could cause slab buckling.
Hydrostatic uplift due to rapid drawdown as described above.
What is the underlying base material? If clay is under the granular then the clay could have taken up moisture and swelled.
Two concrete slabs with a steel plate and granular material in between them?
Is the intent that the steel is the containment and that the granular material is the drainage layer? Which slab has heaved?
Do you know for sure if it’s heaving or settlement around the perimeter?
Rick Kitson MBA P.Eng
Construction Project Management
From conception to completion
www.kitsonengineering.com
What is the underlying soil?
2' is a pretty big deformation, thought... How big is the void?
Doesn't sound like fun either way. Best of luck.
