EPDM AS SHEAR PLY
EPDM AS SHEAR PLY
EPDM AS SHEAR PLY
hi,
I want to use the some material as shear ply between the laminated skirt  and composite pressure vessel joint, for this i have found out that epdm is quite suitable, can any body recomend me some edpm grade and its mechanical properties, especially shear modulus ( which is dependent on temperature). As i want to find out the minimum thickness of shear ply.
Thanks in advance.
RE: EPDM AS SHEAR PLY
although I don't have an answer for you on the EPDM, we have used NBR for shear ply typically 1.0mm and 1.5mm thickness with a 70 Shore A hardness when bonding hardware to carbon fiber.  My question concerns the use of shear ply.  I know it is common in the aerospace industry to spread the stress distribution out through the bondline thickness but there seems to be a trade off between the maximum shear stress that a non-shear ply joint can accomodate and one that has a shear ply used.  At what point, from a pure stress level standpoint, not considering differences in thermal coefficients of expansion and contraction between different material does one use a shear ply in a bonded joint and when is a shear ply not a good idea?  Any direction would be appreciated.  Thank you
