Win95 or 3x emulation in WinXP
I have a scanner (Logitech Pagescan Colour) that is only supported under Win95.
I like this scanner because it allows you to place the scanner head on a large drawing and it will scan a portion of this drawing. Its not something that I have to do often but it is handy to do when I need to do so.
Unfortunately this product is now obsolete and the software is only available for Win3x and Win95 OS’s. Apparently it uses a method of monitoring the parallel port that WinXP does not allow.
Is there a virtual machine emulator that will run inside WinXP and allow me to run a Win95 or 3x virtual machine?
Rick Kitson MBA P.Eng
Construction Project Management
From conception to completion
www.kitsonengineering.com
RE: Win95 or 3x emulation in WinXP
scanning program-> win 95 api->win 95 driver->hardware call intercepted by WXP api->XP driver->hardware
In other words XP still has to know how to drive the hardware.
Options
(1) dual boot to win 95
or
(2) dual boot to Linux which will probably support it - in the interim boot onto a Knoppix CD which is a distro of Linux with quite amazing hardware detection abilities.
or (3) buy another scanner - I've seen several with that feature
Cheers
Greg Locock
I saw a scanner on TechTV "a few weeks ago" that had that same feature - Leo La Porte was doing strange things with it. As I recall, the new scanner only costs about U.S. $250 to $300. Not "already paid for", but pretty cheap.
Have you seen it? Any comments?
Please see FAQ731-376 by VPL for tips on how to make the best use of Eng-Tips Fora.
