Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...The level of expertise is awesome. The nature in which people respond is professional helpful and not the least condescending. I can't say that for most forums..."
Geography
Fretting corrosion and false brinelling.
Gerry45 (Mechanical)
16 Nov 03 9:52
Does anyone know if there is a relationship between fretting corrosion and contact pressure in two microscopically sliding oscillating surfaces ?
I am trying to establish some load limits for ball bearings where there is a tendency to 'false brinell' due to load fluctuations when the brg is not rotating. The application is a wind turbine blade brg.
Some manufacturers have suggested that the relationship resembles a bending fatigue S-N curve, ie. below a certain contact stress level f/b will not occur regardless of how many movement cycles are made. I dont really believe this is the case. I think low contact stresses will create the same level of damage given sufficient cycles. Any thoughts or experience ?
25362 (Chemical)
20 Mar 04 4:16
May I suggest you read chapter 15 on Engineering Tribology by Stachowiak and Batchelor, Elsevier Tribology Series, 24. The heading is "Fretting and Minor Wear Mechanisms". It includes fretting wear, melting wear, fretting due to electrical effects, diffusive wear, and impact wear. It gives useful references, and offers methods for controlling fretting. Good luck.
Close Box
Join Eng-Tips® Today!
Join Us             Close
