install compiler C++ for PRO/MECHANICA motion
I now Pro/mechanica motion(release wildfire) require a compiler C++ to run analisys.But i dont now the good compiler can work(borland,microsoft,etc),and i don't now how to install it.
If you can explain to me,i'm waiting yours tips.
Best regards.
RE: install compiler C++ for PRO/MECHANICA motion
enperigord,
If you are a maintenance paying customer, a great source of information is the PTC "Knowledge Base". Look under the Support Tools heading on:
www.ptc.com/support/support.htm
There were 8 results from searching using the key word "compiler". Perhaps one of these will answer your question.
You should know that PTC is phasing out support of Pro/MECHANICA Motion as a stand-alone product. They have been moving much of the functionality over to modules integrated into Pro/ENGINEER. Mechanism connectivity and analysis can be added to Pro/ENGINEER assemblies by using functionality with the Mechanism Design Extension (MDX) module that is included as a part of Pro/ENGINEER foundation. More advanced analysis can be conducted with the Pro/ENGINEER Mechanism Dynamics Option (MDO) module (www.ptc.com/appserver/it/icm/cda/icm01_list.jsp?group=2...).
What is it you are trying to model/analyze?
The link to the Knowledge Base is in the FAQ Pro/MECHANICA internet resources (FAQ828-702).
Best regards,
Matthew Ian Loew
"Luck is the residue of design."
Branch Rickey
