Does this creature exist / Is this possible ?? slightly urgent...
First off, I'm extremely new at this... but I aint no fool. And sorry about posting in different forums, but couldnt figure out where the best place was to post.
I need a chip/curcuit (maybe single chip??) to read in 3 different wires and for each wire output two others (ie: 3 in | 6 out), but they all need to be different resistances... so for example:
Wire1 is sending a 5V signal at 4.5ohm... this goes into the chip, and then the chip sends out two wires, one at 4.5ohm and the other at 9ohm... (ohm numbers are just for example)
What chips have instruction sets to do this ?? Do any exist ? Cheap easy programming is a serious plus. (Does a 28F020 have logic sets like this ?)
Can analog or digital ICs read in and output resistances ???
RE: Does this creature exist / Is this possible ?? slightly urgent...
they have ADCs and some have DACs which you could use to aid in your circuit
