emf interference with 3 TIG guns and 2.4 diameter laminations
Application:
Three Tig Weld guns at 120 degrees around 2.4 in diameter rotor laminations simultaneously welding
Are you currently doing it, or have you tried it unsuccessfully. Does grounding independently eliminate interference problems?
Thank you
Thank you
