Stainless Washer material
Can anyone recommend a commonly-availiable stainless steel with low galling from which I can manufacture washers. I need the finished washer to be hard >50 HRC.
RE: Stainless Washer material
Come back with the corrosion resistance needed and the size.
I have had good luck with the following company. I would talk with them about your requirements.
http://www.bokers.com/
www.gen-aircraft-hardware.com/template.asp?pagename=was...
I've decided to give 420 a go. For your info, I found some very good material/heat treatment info at the following site:
http://www.interlloy.com.au/
Good luck with your project.
