Saving user preferences before updgrading
I searched through the threads to see if this question has been asked bdfore so please excuse my ignorance if I missed it. Is there a "user prefence" file in SW that contains info like keyboard maping, colors, toolbar locations, etc.? We are about to upgrade and all of us in our group have our own setting that we would like to keep. Any idea? Thanks.
RE: Saving user preferences before updgrading
Start\Programs\Solidworks\Solidworks Tools\Copy options wizard will copy your System options.
Your Templates Part, Assembly, and Drawings need to be backed up. These templates keep the Document Settings for each template.
Toolbars - You would have to export them from your registry. But there is no guarantee that they will work when you run the Reg file. For one the path has to be the same and when you upgrade to a new version the path is different. You will see that when you export your User Interface reg key. Then when you edit the Reg file. Then look at the registry after SW04 is installed. You will see the path is different. If you cahnge the reg file you made and make a global change to the paths you might get it to work. I f it doesn't work then SW won't start and you will have to remove the UI key in the registry and just do the old way, and that away is to redo your toolbars from the beginning. See - FAQ559-655
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
Is that a typo, or a freudian slip? haa haa
Eholmes
The toolbar positions are located in the registry, not the *.cus file.
Go to your regsitry and follow this path: HKEY_CURRENT_USER\Software\SolidWorks\SolidWorks 2004\User Interface\Toolbars\PartTool
AssemblyTool and DrawingTool
When you switch between part, assembly or drawing the toolbars can be located in different spots. That is what these paths are for (Above).
If you have SW03 installed and then install SW04. Your toolbars are going to show up in the same fashion, because it more less copies the previous Reg entries from the previous SW.
Scott Baugh, CSWP
FAQ731-376
You've created a new word.
Crashj 'somedays you're a bug somedays you're a feature' Johnson
