Moving a Spline
Moving a Spline
If I made a spline in a drawing is it possible to make the spline defined? I mated the two endpoints on the spline and when I change the configuration only the endpoints move skewing the spline. I currently select the whole spline, ctrl+drag on it to move it and remove the mates then move it close to the new position. I would like this to be automated when I change the configuration, where the spline is set but movable as a whole. Thanks
RE: Moving a Spline
I'm not sure what your doing so more information would help.
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
RE: Moving a Spline
