Create a separate drawing from a sheet
There is a way to create a separate drawing file from a sheet of another drawing file?
Thanks!
ediushu
RE: Create a separate drawing from a sheet
I got the answer. It's pretty simple actually. Save the drawing file as a difrent name file and then remove the sheets that you don't need.
ediushu
You can also MERGE the drawing into a drawing and then delete the sheets not required.
maybe only a drafter
but the best user at this company!
