alternative to .EXE files
Hi Guys,
Some ISP's won't allow .EXE files to be sent by e-mail.
What's the easiest cheap alternative?
Thanks a million.
Thanks a million.
RE: alternative to .EXE files
I use a program called 7-Zip; it does a great job of compressing. And it doesn't contain adware or malware (to my knowledge.) You can check it out at www.7-zip.com -
7-Zip is free software distributed under the GNU Lesser General Public License. And it can also be found on Source Forge.
Please see FAQ731-376 by VPL for tips on how to make the best use of Eng-Tips Fora.
Some versions of Outlook will also block access to EXE files. There is no setting that can be changed to allow access since this “protection” is built into Outlook.
A program called EZDetatch from www.techhit.com will allow access.
Rick Kitson MBA P.Eng
Construction Project Management
From conception to completion
www.kitsonengineering.com
copy/b f1+f2..etc.. combined.exe
<nbucska@pcperipherals.com>
DickRussell's tip did the trick for me, but all the other replies were informative and helpful.
Best wishes to all for 2004.
JWB46
