images in headers
images in headers
Is there any trick to insert an image .BMP in the header of a document?
I've tried to scale it according to header dimensions, but I can't view on print preview.
Some ideas?
Thanks to all!
Some ideas?
Thanks to all!
RE: images in headers
[It would be much better if you could just drop in any graphic, not just a bitmap.]
Bung
Life is non-linear...
header:="drive:path\filename.bmp"
and enter the text 'header' (without quotes) in the placeholder of the picture (Ctrl+T).
That way you can put the header in a separate bmp file outside of the mcd file. Editting the bmp file will change the way the picture looks in the mcd file. Resize it as much as you wish till it looks good.
This keeps the mcd file rather small, especially if you have a large number of pages...........
